Differential pinion seal
20,771
Hi friends, what kind of oil seal do you use for the differential carrier? I don't want to give it N.O.S.
So... On a Deuce... Guessing that you should be able to remove the seal without wrecking it? Hopefully you can see the part number on the seal - then start searching the web for a replacement?
I was a little disappointed that the Deuce Parts List didn't have one listed. I would take the seal to a truck parts house just to compare it to what was in it...
  • Like
Reactions: HDN
HDN
5,564
Finger Lakes Region, NY
Is "carrier" the right word here? I'm not super-familiar with differentials, but from the pictures I've seen of differentials on the internet, the carrier is completely inside the differential housing and should constantly be getting oil:
@Lukas Avkovsky Is there another part you're referring to?
HDN
5,564
Turns out I needed to look in a different parts manual, which I managed to find here. TM9-2320-361-20P has these parts listed:
Part #7521241 SEAL,PLAIN ENCASED
A quick Google search seems to indicate you can get these seals new and not just NOS.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
