- 83
- 11
- 8
- shelton/CT
Hello I put a winch/pto from an m809 on my m52a2, when I pull the lever up the winch drum spins forward like its paying out cable and in the down positions low/high the drum spins backwards towards the truck like its winching, but everything ive seen and read said it should be the other way? As far as I know the pto/driveshaft only work one way, is it possible something in the winch is reversed? or am I completely over looking something? right now the cable has to be under the drum to winch but it should be over the drum. Thank you.
