- 1,553
- 1,801
- 113
- Puget Sound, WA
I was shocked on how fast mine goes thought the fuel. Drive up to Skykomish and around Index and that's a half of tank. I haven't driven the LMTV much this year but just looked and filled it last September and it still have over 1/2 a tank... and it's been on the same Sunday drive a few time since. Granted the tank is twice as big as the my HMMWV.It seems like it's all over the place. I suppose it's because I'm not stopping the pump at the same place every time.
That last time I read my TM it said Dexron III, which is near impossible to find. After asking others here, I have been using DexMerc without any noticeable issue.Hello everyone. I just changed oil and greased the M1097R. But I have a question I’m sure it was brought up before, But I’m looking through the TM’s and I can’t seem to find the ones for the M1097R, So I have been following the M998 one. My question is I’m getting ready to change the transmission fluid transfer case. The TM shows Dexron 2 which I know to use what GM calls for now to use for that. But online I’m seeing not to use Dextron but to use AC Delco 10-4033 in the transfer case on the M1097R . Am I safe to follow the old M998 Dextron or switch. Thank you
The M1097R is a recapitalization program truck, upgraded from a different version into a heavy variant. Not an actual factory variant of the truck.Hello everyone. I just changed oil and greased the M1097R. But I have a question I’m sure it was brought up before, But I’m looking through the TM’s and I can’t seem to find the ones for the M1097R, So I have been following the M998 one. My question is I’m getting ready to change the transmission fluid transfer case. The TM shows Dexron 2 which I know to use what GM calls for now to use for that. But online I’m seeing not to use Dextron but to use AC Delco 10-4033 in the transfer case on the M1097R . Am I safe to follow the old M998 Dextron or switch. Thank you
The only caveat to what Coug said is that if your M1097R1 has a 4 speed and a GVWR of 10K (vs10.3K) it has A1 half shafts, hubs and springs and possibly drive shaftsHello everyone. I just changed oil and greased the M1097R. But I have a question I’m sure it was brought up before, But I’m looking through the TM’s and I can’t seem to find the ones for the M1097R, So I have been following the M998 one. My question is I’m getting ready to change the transmission fluid transfer case. The TM shows Dexron 2 which I know to use what GM calls for now to use for that. But online I’m seeing not to use Dextron but to use AC Delco 10-4033 in the transfer case on the M1097R . Am I safe to follow the old M998 Dextron or switch. Thank you
if you are strictly on road/near roads, in other words not really taking it away from improved roads like the jeep trails, then it's entirely your choice.Good evening guys. I’m looking for opinions. I’m replacing the tires. Do I reinstall the run flats or not. Some day they ride better without. But it wouldn’t be original. I’m not really worried about someone shooting my tires but then again with this world who knows. Let me know what you think.
