What have you done to your HMMWV today/lately
155mm
Chief and Indian
507
Guymon, OK
Got wiring issues fixed with inverter, installed 24v air compressor and tank, welder reinstalled and wiring chased down (with many thank you's to @aghumvee for his time)
next will be a test tickle with a ford alternator to verify the 'not under the hood' under the hood welder works before investing $500 in a 12v 250amp alt.
then maybe paint it all, truck is very faded compared to newer box and both doors are new, so need to color match them all
got battery cables delivered and installed for the 6ea group 31 batteries placed in right rear floorboard
finally got motivated to build the passenger side filler door.
aghumvee
222
Blairstown,Missouri
It looks awesome!!
Hmmm....maybe we should have switched boxes since mine is camo going on a solid green M1097 and yours is green a camo humvee. :ROFLMAO:
155mm
Chief and Indian
507
Guymon, OK
It looks awesome!!
oh, now you are going to make my head hurt, but now would be the time to swap before I start really loading it up with the toolboxes, oxy/acyt reels-tanks, air hose reels.
hgun
382
Leechburg, PA
I got all the fun flats out. 3 out of the 4 had 2 piece run flats big round one and a little on then sits on the other one I can say they were much easier to install than the big one. Time to clean and paint the wheels and reassemble. I’ll keep you updated
hgun
382
Leechburg, PA
I got all the hub fluid changed. When I removed the dust cover to torq the 3/4 bolt to I noticed the lock washer was laying inside the dust cover they must have said oops we will get next time lol. And one nut didn’t have the tabs bent into the grooves. So now I’ll start cleaning the wheels and reassemble.
HookEm
39
13
Central Texas
So I had been chasing a power steering leak for quite some time, intermittent issue so that was fun...
Anywho, for those with the M1152/A2 with the big alternator, the hose off the Cadillac valve to the cooler (the aux cooler at the passenger rear fender well) runs dangerously close in a pinch point between the alternator and body.
I am assuming this isn't an isolated issue as when I went to my parts rig it had the same issue. Now off to find a hydraulic shop that can make up a new line, or I may try and jerry rig something, cant find the part online for the life of me.
Would hate for someone to go crazy trying to find this leak, changing the PS pump, hydroboost, steering gear... because that would just be nuts... I mean who would do such a thing...
KKroger
231
KC MO
A Little While back I added A/C to my 1097R1
Red Dot Evaporator, Sanden 508 Compressor with 24VDC Clutch, BlackDog Customs Compressor Bracket, Red Dot 5 groove water pump pulley. bunch of hose and fittings and a parallel flow condenser from Coldmaster, and a simple wiring harness. works quite well.
Ended up with the condenser on the cooling stack dual fans, Had a minor issue with the manifold gages I used for automotive the low side valve stopped working. had to use a consumer trigger hose. Meh it worked. Designed and 3D printed from ASA plastic some Square to round duct transitions. Fabricated the Evaporator brackets from 3" x .125 aluminum angle (6063) a bit ham handed but they work. Control from Coldmaster. has 4 speed fan and rotary temp control there is a thermistor in the evaporator. I put mesh wire wrap around the main forward to rear trunk, this is all 24VDC so the main power comes right off the batteries just like the Red Dot setup. the Evaporator arrived brand new in a Red Dot Box Damaged... the plastic duct around the dual squirrel cage fans was broken so when first powered up the fans were rubbing and dragging so bad it started blowing fuses and burned out the speed controller. I initially repaired with nylon Zip Ties, Coldmaster shipped a new same manufacturer fan assembly immediately. While it is still uninsulated the system pours 41 degree air on my head. and reduces 105 degree air to 80 degrees and lower ambients to much less.
A Bit of Simplification.
the smallest hose is the high pressure "Liquid" line, the Largest is the "Vapor" line or lowest pressure, the MIDDLE size hose is the high side of the compressor. smallest is #6 Largest here is #10 and the "Middle" is #8 so if we start at the Compressor Number 8 goes to the TOP of the Condenser, #6 comes from the bottom of the condenser, that goes all the way back to the Dryer, which is the canister shaped item. from THAT to the EVAPORATOR in is also #6 then #10 is the return that goes back to the compressor. you can see in the thermal pics attached that the dryer and high side lines are quite hot. the lines all run UNDER the Hump Floor over the transmission and exhaust I WANTED to use a bulkhead connector in the floor there and had it but the supplied fittings for the dryer were Straight not right angle so for my mounting solution they would not work. Most mount the dryer on the fender liner on the passenger side. it would not fit there for me. so it is alongside the evaporator. as shown. the Red Dot instructions show the Dryer mounted outside the cab on the back wall. and the condenser is also on the back wall or the roof. I chose not to do any roof penetrations on the Helmet top. the Condensate drains go through the floor behind the evap. I tied them to a stainless Tee fitting there.
20,816
Removed the bench seats
Hoping maybe you saved them to re-sell on the site?
either or
77_M890
17
Vancouver, Washington
Yes I still have the benches. I’m talking to a guy in OR off of Craigslist about a possible trade. So far I would like a brush guard and a spare tire carrier, but he only wants to give up the tire carrier.
77_M890
17
either or
I don’t think I’m allowed to yet?
Gcelevator
807
Fort Lauderdale, Florida USA
The lift mechanical pump on the 1123 left me kind of stranded last week. Installed a Facet electric pump 4-6PSI and has been testing fine so far. Bought a new mechanical pump from HPG but will not install in the near future and when I do, i will leave the electric one in place for emergencies.
Used my jumper to start the truck with the 1151.
