What have you done to your 5 ton this week?
Valley Rock
Big wheeler cat peeler
934
OR
M931A2
I eliminated the fuel tank control valve in the cab, now fuel pump is hooked directly to the drivers tank only .
No more air leak from that valve, I will run a balance/transfer hose from the bottom of the tank to the other tank like it should have been made in the first place, instead of that complicated air leaking spaghetti mess they came with .
It already runs better .
