What have you done to your 5 ton this week?
Valley Rock
Big wheeler cat peeler
938
OR
M931A2
I eliminated the fuel tank control valve in the cab, now fuel pump is hooked directly to the drivers tank only .
No more air leak from that valve, I will run a balance/transfer hose from the bottom of the tank to the other tank like it should have been made in the first place, instead of that complicated air leaking spaghetti mess they came with .
It already runs better .
US6x4
2,532
Wenatchee, WA
I made a weird bracket that straddles the back of a cargo hold down to mount my VRC antenna base and antenna element. I mounted it to the passenger side so it wouldn't interfere with unloading a full size spare tire and because the radio is also on the passenger side.
Next up is to wire up the aerial and install the radio under the seat!
Another Ahab
4,979
Alexandria, VA
Nothing weird ay all about that fabrication, US6x4; that there is an excellent piece of work!
Valor
229
Apple Valley, Ca.
Could you make some more brackets?
