M561 M792 Modification Work Order (MWO)'s
wsucougarx
65
Washington State
Is there a manual or publication out there going over the MWO's for the Gama Goat? So far I have only found one:
Modification Work Order 9-2320-242-35- Driver/Passenger Seatbelts
Anyone have the listings of the other? Or have a MWO data plate on your dash stating the numerical MWO code?
m38inmaine
102
Maine USA
Not listed as a MWO but I do have drawing 12296488 Instruction, engine electrical harness replacement kit dated 3-14-80. This shows the new harness that bypasses the large negative/positive at the harness connector.
m38inmaine
102
Maine USA
MWO 9-2320-242-50-1 is a MWO to modify brake pedals from rubbing the steering column. My goat has this number scribed on the top of the data plate.
m38inmaine
102
Maine USA
TB 750-981-1 JAN 73 technical bulletin contains information preventing defroster from cracking windshield. Rotate defroster duct on dash 180 degrees, modify diverter to allow less air.
m38inmaine
102
Maine USA
TB 750-981-2 April 73 contains special repair information for Gama Goat such as cold start air pump, wiper motors and accelerator install. Would be nice to find a copy of this.
m38inmaine
102
Maine USA
TB 43-0001-39-3 and -4 preventing water getting in steering boxes, relocating engine stop and throttle cable.
Jericho
72
Landaff NH
Didn't know there was a TCTO (AF speak for Time Compliance Technical Order , equivalent to and Army MWO) on this , BUT did it after noting the interference . lol (involved a saw zall and grinder)
Guyfang
27,074
Burgkunstadt, Germany
This thread is 9 years old, since the last posting. That is indeed a MWO plate, and its for the MWO to modify brake pedals from rubbing the steering column. It also shows you the month and year that the MWO was applied.
