85 M1010 Resto/Build Thread
NortheastNick
25
13
New Hampshire, USA
Been a while since I've been back, went to the Weare rally last year and worked out a deal with Mike Morin and bought an 85 M1010 off him right before I left for basic. The green iron itch doesn't go unscratched, I suppose. Got it home and have been dealing with the usual ex-FD issues. Had some gnarly fuel in it (Smelled like a mix of wood stain and gear oil), and the IP was all kinds of messed up. Cleaned it and ran some distillates through it, got it running a bit better. Have a reman coming in the mail along with injectors, fuel pump, return lines, and a filter. Have some electrical issues to deal with when I'm back home again, something caught in the fan circuit. Will be getting the doghead mod, GP resistor bypass, and LMC headlight harness upgrade. Managed to find a NOS spotlight as well. Got my paint and primer on order from QTM and stencils/decals, going to have a lot of work for me when I come home late July.
Happy to be back in the game with some old iron, gonna be bringing it with me to my duty station in Alaska this fall. 4000 miles up thru Canada, how wrong can it go...
76012792306__E0EAC783-ED57-4FA9-B191-BFC6DC81A4D5.jpg76315462925__FD75BEBB-5C46-4235-B088-7AC6600D14A8.jpgIMG_0051.JPG
deank
696
Inverness, Florida
When you get to Alaska, I have a couple of former students stationed there, depending on the unit you go to.
Looks like you got a good find.
NortheastNick
25
13
New Hampshire, USA
I'm up here now, truck is sitting with the folks for the summer while I build up some more leave. I'm over on the AF side but try to circulate as much as I can, networking is half the battle up here. Trying to find some people to wrench and wheel with as time goes on.
The truck was definitely a solid find. I don't mind the electrical work, and it's solid and fairly straight as it is being an Arkansas truck. Interior feels like the 38k the odometer reads.
NortheastNick
25
13
New Hampshire, USA
Very cool! I’m working on an M1010 in central Mass. It makes a great travel vehicle, assuming 55mph is okay.
Absolutely, shaping up to be a fun drive cross country with it. Aside from the speed, had any gripes about running it long haul?
Got near all the stuff to put a functional PLGR in my truck, just hunting for a dash radio bracket to mount it to.
Spence
80
Massachusetts
I had no issues. I kept it at around 55mph the whole way, so it took a bit longer than typical in other vehicles. I loved it though. I’ve spent today working on mine after it developed an issue where it blows a fuse installed by a previous owner. Its a fuse that ties into the ignition circuit and has rendered the truck immobile for a while. I inherited it as a basket case with wiring all hacked up. Looking at going back to original wiring and going from there. I hope yours treats you well. They are fantastic vehicles if you value character.
NortheastNick
25
13
New Hampshire, USA
Finally back in the lower 48, and it’s been a busy few weeks. Nearing the end on paint and bodywork stuff, replaced glass, some suspension refresh, new IP, chasing some electrical faults, rebuilt the column and working on radio installs and interior stuff now. So far it’s been shaping up half alright. Should be getting alternators back from overhaul tomorrow and will be diving back into electrical faults after.View attachment IMG_3434.jpegView attachment IMG_3513.jpegIMG_3487.jpeg
Spence
80
Massachusetts
Finally back in the lower 48, and it’s been a busy few weeks. Nearing the end on paint and bodywork stuff, replaced glass, some suspension refresh, new IP, chasing some electrical faults, rebuilt the column and working on radio installs and interior stuff now. So far it’s been shaping up half alright. Should be getting alternators back from overhaul tomorrow and will be diving back into electrical faults after.View attachment 951973View attachment 951974View attachment 951975
Those radios look so cool! I have been shopping around for radios to install into my M1010. I have a general class ham license and am excited to have a mobile shack. Thanks for sharing!
NortheastNick
25
13
New Hampshire, USA
Got most of my shakedown done and major issues sorted out, unfortunately not going to be able to get the truck bac up here this year, but it buys me more time to get the stacks of little things squared away and find someone with the majority of the components for the box. It's been a very good, well mannered truck and wheels outstanding. Put about 700 miles on in the 4 days I had before I flew home without much of an issue. The goal for next year is to remediate the oddball electrical and fit/finish issues, fine tune my comms gear, get the patient compartment sorted out, and finish up marking it out. After that, north to Alaska.IMG_3528.JPGView attachment IMG_3531.JPG
It's definitely worth it, the VRC-12 I installed can be a little tight depending on how your brackets and floor pan all line up. With the compounding tolerances on mine it barely rubbed my dash, and I lost access to my glovebox and ash tray. It's a slick setup for show or if you don't bank on passengers much though.
NortheastNick
25
13
New Hampshire, USA
Nick where in NH are you?
I'm right on the Portsmouth/Kittery line.
I'm in Loudon when I'm back, but I bounce back and forth between Alaska and home when I have leave. Should be back again mid spring to summer of '26 and I'll be all over the state for around a month. Would be a pleasure to link up with someone else in the community as I haven't been able to make it to Weare or any events for a couple years now
