RARE FIND - New Mile Marker 10,500 57K3541 Winch
4x4nutz
136
Mico, Texas
I bought some crates from the family of a big Humvee guy out of Kerrville, Texas who passed away. At the bottom of one crate I found the winch with everything. My question is, can I make this Mile Marker 10,500 (Model# 57K3541) fit one of my ECV trucks?
juanprado
3,233
Metairie/La (N'awlins)
Ken modified this winch to make it work on a ecv.
Check out this thread for some info;
4x4nutz
136
Mico, Texas
I had read this before I posted, but it looked like it would be too much of a hassle. Thank you though.
kendelrio
9,592
Alexandria, La
The ECV not only requires a new winch plate, the solenoids are on the opposite side of drum….its a pita to install on an ECV.
100% this. I just did this and i had to jack the motor around, reorient the winch, order a new plate and hoses and slide some chafing gear between the motor and my radiator hose. You will also need different frame extenaions. My $500 winch cost me an additional $2500...
If you are going to do it, PM me your number and I'll be glad to walk you through the steps.
4x4nutz
136
Mico, Texas
I have a
Has anyone seen the ECV specific winch setyp for sale?
I have a winch on an 1114, but it's set up for the rear. Been wanting to take it off as I am parting out the M1114. There is no remote and the system itself is kinda weird. Judging by the cable and how its perfectly wound, I don't think it's ever been used...buit then it's been sitting under this M1114 for about 9 years...
86humv
545
Texas
I put an electric warn 12k in an ECV....it takes longer brackets, and a different mount.
They are Hmmwv parts I found years ago.
Dont know part numbers....way more heavy duty mounting than the 9 k electric, and 3 times more bolts.
Mogman
10,601
Papalote, TX
The 12K gives you more mounting options than the 10K
