M1078....flasher
coachgeo
3,551
North of Cincy OH
There should be a black box under the PDP (fuse box) on the passenger side.
hmmm.... on the A0... seem to recall differently
Is the A0 and A1 or A1r in different places?
Ronmar
8,380
Port angeles wa
Under, meaning under the entire dash behind the passenger kick-panel… aluminum heat-synced case with 3 pin cannon plug. Replaced mine with a solid state flasher module…
Ronmar
8,380
Port angeles wa
I used this 3 wire 12A commercial unit from Grote(#44010). Same 3 inputs, B+ in, ground and pulsed/flash output… Removed the cannon plug and used male/female spade connectors, ~10min installation…, ~$35 online…
mikemike1079
colorado
BBeautiful thank you
Beautiful I'm going to order that right now thank you
