06 M1165 AC Issue
Nethawk86
Litchfield Park, AZ
Just picked her up. Owner said he never messed with the AC but when he connected the 3 wires under the passenger side dash and turned the key, it started smoking, so he unplugged it. Vehicle is in very nice condition, and besides a very hard shifting transmission from 1st to 2nd (will figure that out next after fluid changes), its killer! I took off the dash vent shroud cover to repair all the heat cracks in the plastic (since everyone wants $700+ for it) and figured id try and see myself what he was talking about. The 3 wires only connect 1 way, so there wasn't any chance he connected something wrong (which he did with the tail lights when he upgraded to LEDs). Factory AC, 6.5 Turbo Diesel, 4L80E.
Plugged them together, turned the truck over into RUN, not starting the engine. Then flipped the fan switch to High and I could hear the fan pulsing a few times before smoke came out followed by a "PFFFFT" sound. Smoke was definitely electrical in smell. Immediately turned off and let it sit for a few minutes. Checked over everything and nothing seemed burned on the outside (but will check thermal next). Unplugged the wires, turned the vehicle back over to RUN again and flipped the fan switch to HIGH and then LOW. Both working fine now, not pulsing or anything. So fan/blower motor works fine when not connected. And the smoke/sound came from the unit under the passenger dash where the blower motor is.
DREDnot
639
Avondale , AZ
How was your rear AC evaporator/blower box acting during all this?
What were the numbers on the metal tags on the wires you were unplugging?
DREDnot
639
Avondale , AZ
Those go into a small black box on the side of the evaporator assembly, correct?
That is the "temperature switch" that senses if the evaporator core ices up and shuts off the compressor till it thaws out. The two skinny white wires are for the temperature probe.
When the wires are unplugged the fans (front and rear) run, but the air that comes out is not cold because your compressor is not engaging, correct?
If you plug the two wires 438A and 435D together it effectively bypasses the switch and your compressor should kick on and make cold air.
Nethawk86
Litchfield Park, AZ
plugged them into eachother and I started the truck. Heard the fan pulsating again, and the smell...but no smoke, so I think the smell this time was just residual in the coils. Let it run but never got cold. Flipped over to heat and it heated fine. But no AC, and the back box wasnt working at all. Let it idle for a while and never got cold. So maybe low on freon....or whatever smoked....is finally dead after doing it twice now lol. I did leave the temp probe connected
DREDnot
639
Avondale , AZ
The broken hot water shutoff valve is a common ailment. Most folks replace it with a 1/2" ball valve with 5/8 hose barbs to manually shut off the hot water when not needed.
The temp switch that fried can be replaced. Avoid the older model with the white label and find the newer model with the tan label. Hopefully the thermo bulb in the evaporator core isn't the cause.
Where did you pull codes from?
Was your compressor clutch engaging?
It could be out of freon like you said. You could put gauges on it if you have them or take it to an AC shop to get it vacced down, leak checked and recharged.
Nethawk86
Litchfield Park, AZ
I pulled from the TCM system shorting A and E and reading the trans code. I think the compressor was because when I turned it on AC the vehicle RPMs and sound was "pulsing" whereas before it just ran without any difference in sound. I have some guages, will toss them on and check.
What's the purpose of the flow valve? And doing the ball valve mod would do what? Im in AZ so it only gets cold here for like 3 months. If it'll save me the $220 for a new flow valve system and doesnt really effect anything, im all over it. Hopefully between the temp switch and flow valve, the back AC box unit will kick on also. No idea also how to get what looks like the ground wire to it off....it looks to go inside the evap unit itself.
I do have a dripping and leak at the below part and im not sure what it is. I cut the end of the hose as it was frayed and reinstalled, but still getting a drip at the clamp. Then around the bottom bracket for it where the bolts are, the gasket sealer looks to be coming off and it seems like oil is leaking from there.
DREDnot
639
Avondale , AZ
the engine fan pulsing(?) sound could be the fan clutch engaging and disengaging if thats what you are talking about.
the flow control valve shuts off hot engine coolant from circulating through the heater core. The HVAC air passes through the AC evaporator first and then through the heater core. if the flow valve leaks or is stuck open the cold AC air is reheated before blowing into the cabin. Cheap easy fix is that home depot ball valve.
the rear AC may need the recharge to close the low pressure switch, and bypassing the temp switch by connecting the 438A and 435D wires that can start the compressor turning.
The ground for the temp switch module is routed around the front(forward) side of the unit housing and attaches to this stud under this wire. {If I Remember Correctly...}
Leaking item is your mechanical fuel "lift" pump. had quite a few that have a leaking diaphragm that drips off of the hose and clamp. Learn up on the intricacies of replacing the pump while minding that devil of a pump rod and it will involve re sealing that mounting plate as well
Nethawk86
Litchfield Park, AZ
Correct. Thats what I was meaning by responding to your question if the AC clutch is working/engaging. When the AC switch is on, it pulses, when I disconnect the thermostat connectors from themselves and hit the AC switch, no pulsing.
Yea I watched a video of a dude replacing his fuel pump due to it leaking inside his vent lines. As I've already had my hands up there trying to tighten the bolts to try and stop the leak, its a very tight space to work for sure! Im just debating if I should replace just the gaskets, or say f it and since I pulled it off already, replace the pump and rod as well......
Nethawk86
Litchfield Park, AZ
Yeah mine isn't attached there. Theres 2 ground wires attached.....but they're not the thermostat. I see the wire go into the box just above the heater core.......looks like I have to split the box open to get to it
DREDnot
639
Avondale , AZ
Yikes. You will have to pull the whole unit out opening the freon system. That plastic shell has the structural strength of an ice cream cone.
The system doesnt need that temp switch to run. You can just plug those two wires together like in my pic.
I dont remember that ground going inside the box. Only the probe did.
I would recommend just cutting the ground and routing the new one to that stud before I would open that housing up.
Nethawk86
Litchfield Park, AZ
Part of me wondered if that was the cause of the failure. Maybe the ground wire got cut and arched on something inside. Some 18yo yahoo routed it incorrectly or something and didnt check to make sure the wire was clear of anything before tightening stuff down. I should call the factory for a warranty claim!!!!!!! Lol. I was toying with the idea of cutting the wire...but wasnt sure if It HAD to go in there for something.
Nethawk86
Litchfield Park, AZ
While I got you on here for a bit. What're your ideas on "fixing" stripped out holes on the frame for the soft door strikers? Looks like some German applied some good Ole goodentorque and stripped out most of the holes and then used incorrect thread pitched bolts to pull the rest out. So the holes are just that. Now, given where the bolts are....there's not lots of meat and it seems like they had thread nuts welded on the inside which are now AWOL. So, I could just tap the holes, but that probably wouldnt hold well. I could insert a thread plug/rivet, but its gonna protrude from the frame a bit which am not sure for door fitment. Cut/mill a thicker strip of metal that goes over the holes and will bolt to the frame and then drill and tap new holes.....but once again....will be sitting higher on the frame and may cause door fitment/lockup issues.....
DREDnot
639
Avondale , AZ
Theres actually a threaded plate that fits in that channel behind there.
NSN 5340-01-197-5477
On ebay right now from a great seller i know. militarysurplusparts out of Hesperia, CA
search " M998 HMMWV 4 NOS HARD DOOR STRICKER RETAINER ASSYS 12339006 "
Nethawk86
Litchfield Park, AZ
Those say for hard door and they go behind the door strikers....I dont have hard doors. And my front strikers and just screwed into the frame, albeit using the wrong bolts so they're stripped....but the frames have some type of threads/nut welded into it.
DREDnot
639
Avondale , AZ
They will work for both. Hard strikers and soft wire catches. I switch between the two all the time.
You can just use 5/16 bolts and washers just as well but the plates are way easier to adjust
Nethawk86
Litchfield Park, AZ
Outstanding! Before I left for work this morning I dug into it to check a few things before I ordered parts. Regarding the TPS low voltage issue, I heard some people say they had a wire disconnected down the line. I was gonna throw on my voltmeter to test the voltage range of the TPS anyway. Followed the wire and found a disconnected plug by the dog house next to the fuel filter. Read 3 of the tags which were 358H, 350(?), and couldnt read the third. But kinda quickly skimmed through what I could find on the electrical diagram and see it "looks" like is the TPS connection.......now why the H did someone disconnect it?!?!?!?
Nethawk86
Litchfield Park, AZ
Got home tonight and went back over some stuff. That was 100% the TPS connection. So I drove a bit around and while the RPMs are stupid crazy high and it likes to hold onto 1st for a while, it shifts much easier now....much. Wonder how long its been driven around like that and if any damage has been done to the trans. Im sure the high RPM thing is the pully on the 400amp causing it.
But rechecked the codes and not get anything anymore, so alls well on that front. I may adjust the brake rod switch bar to activate earlier on the pedal. Im gonna get a new fuel pump as it seems like its leaking at the seam....but I cant really tell.
The ground wire on the thermostat was pinched in the box and WASNT connected to that ground post, so wonder if thats what smoked it. So I cut and removed it. So routing the new one will be easy.
I threw on my AC guages and got nadda. Theres no refrigerant in the system. Will have to take it down and have them replace all the seals/orings and recharge/test for leaks. But still, not hearing the compressor kick on, and found the back AC box wasnt even connected. Hooked it up, but still got nothing working on it. Not sure if there's a safety feature or something that when no refrigerant is felt, it turns off the motors or something? Removed and lifted the box gently and the fan blades spin freely, no frayed wires. Checked continuity from the harness by the passenger seat to the connector and it all checked out on the 4 wires.
So no idea, and cant find what pins are ground/voltage on the diagram to test if the connector is getting power or not. But while the AC is empty......I found a leak at the radiator, but no idea on size or location. So since there's no freon, I may pull the stuff apart now to get access to stuff before the system gets charged. Any idea what this hose is next to the snorkel? It leads to something that looks like a filter, but its been cut.
DREDnot
639
Avondale , AZ
TPS may need to be adjusted. There is a procedure in the 4 speed transmission handbook that involves taking voltage readings at different throttle positions. I dont have my book handy at the moment though.
Be careful adjusting the brake switch. There is half a hair sweet spot between the Normally Off brake light switch coming on and the adjacent Normally On torque converter clutch switch coming off. Minimal pedal travel doesnt help. You need to find the finest edge between your brake lights not coming on or your torque converter clutch never locking up. Horrible design.
Try to find an OEM (non chineseum) fuel pump. You dont need the one with the top vent fitting unless you want to recreate the Deep Water Fording system.
Make sure to watch some instructional videos to familiarize yourself with the cam to pump arm actuating rod handling techniques
Compressor and fans wont turn on if the system is empty of freon. Thats what the low pressure switch does. You can get a can of R134 and get some in the system so they can find any leaks.
Any wire marked with the number 7 is a ground. 7, 7A, 7B, 7C, etc. The main power for the system comes from the two circuit breakers that reside in a bracket located just off the floor outboard of the battery box proper under the front passengers right buttcheek
Wires445B/661A and 720A/660A.
720A is the power feed to the rear evap units internal relay.
Print out that AC electrical diagram as its the golden key to understanding the AC electrical system
That filter gizmo is part of the fuel tank vent hose. The end you are holding used to attach to the fuel vent pipe on the snorkel. Non Deep Water Fording hmmwvs fuel tank vent ends with that filter. The filter keeps dirt and bugs out while allowing the tank to "breathe" so make sure you can blow through it. If not replace it. Its an old 70s ford fuel filter.
Any parts you need for the AC like new orings and the seal washers go here to get what you need. Bring yours to match up. They are at 27th ave and McDowell. They dont do the work but supply all the shops. They made my hoses to adapt my M1165 style fender mount system to my Red Dot Sanden compressor while I waited.
AAPAK - Auto a/C, Auto Parts, Auto Parts Store
