06 M1165 AC Issue
Nethawk86
Litchfield Park, AZ
TPS may need to be adjusted. There is a procedure in the 4 speed transmission handbook that involves taking voltage readings at different throttle positions. I dont have my book handy at the moment though.
Be careful adjusting the brake switch. There is half a hair sweet spot between the Normally Off brake light switch coming on and the adjacent Normally On torque converter clutch switch coming off. Minimal pedal travel doesnt help. You need to find the finest edge between your brake lights not coming on or your torque converter clutch never locking up. Horrible design.
Try to find an OEM (non chineseum) fuel pump. You dont need the one with the top vent fitting unless you want to recreate the Deep Water Fording system.
Make sure to watch some instructional videos to familiarize yourself with the cam to pump arm actuating rod handling techniques
Compressor and fans wont turn on if the system is empty of freon. Thats what the low pressure switch does. You can get a can of R134 and get some in the system so they can find any leaks.
Any wire marked with the number 7 is a ground. 7, 7A, 7B, 7C, etc. The main power for the system comes from the two circuit breakers that reside in a bracket located just off the floor between the front passengers right buttcheek and the rear passengers right foot.
Wires445B/661A and 720A/660A.
720A is the power feed to the rear evap units internal relay.
Print out that AC electrical diagram as its the golden key to understanding the AC electrical system
That filter gizmo is part of the fuel tank vent hose. The end you are holding used to attach to the fuel vent pipe on the snorkel. Non Deep Water Fording hmmwvs fuel tank vent ends with that filter. The filter keeps dirt and bugs out while allowing the tank to "breathe" so make sure you can blow through it. If not replace it. Its an old 70s ford fuel filter.
Any parts you need for the AC like new orings and the seal washers go here to get what you need. Bring yours to match up. They are at 27th ave and McDowell. They dont do the work but supply all the shops. They made my hoses to adapt my M1165 style fender mount system to my Red Dot Sanden compressor while I waited.
AAPAK - Auto a/C, Auto Parts, Auto Parts Store
Outfreaking standing! Yeah, mine is a deep forger, has mostly everything and what's not installed, came in a box including the valve and such. Will definitely do the can of r134 idea with dye to spot leaks. The front and back are seperate units correct? Each with their own ports to put freon in?
Nethawk86
Litchfield Park, AZ
All one system. Just one high side port and one low side port up by the compressor
Got any pics of the whole truck?
Awesome! Im gonna try and find a replacement radiator before i put any freon in since i more than likely will take the disconnects off to just make it easier and not break anything, so might as well do the radiator now and not have to loose money on charging the system only to discharge it later. I have to pull off the tires and replace all 4 plus the spare here too, the hub rings just arrived, so ill take these down to Nunez after I pickup the new tires. So while its up, ill pull the radiator and see how bad the damage is and if its worth repairing/welding or just replace it with either a champion or a take off.
Yeah, heres a quick pic. Been dealing with this guy for over 6 months now trying to buy it. He had it on marketplace but the guy posted it and just kinda....ignored it and only checked in every random month or so. It was a real PITA. I thought it was a scam at first due to price and him deleting/"selling" then relisting it, but I managed to find out it was a real deal. Guy said he got fed up with tire kickers and kids who dont know about Hmmwv ownership and he didnt want to deal with that headache.
Then he had this in a Trust which trying to get the title transferred was a real nightmare from the MVD. After 3 days and 5 trips to different MVDs, they finally transferred it. However, unlike my old 1988 M998 where it was emissions exempt, allowed to be registered for 5+ years, and insured for $40 and cost $20 to register, they made this one a commercial vehicle which requires emissions, only allowed 1 year tags for $75, insurance commercial'd it also and costs $117. I was just happy to get it titled after it all that I said id deal with this all later. But now am wondering if this thing would even pass emissions given it was never meant to. I may get classic insurance to bypass the emissions worst case.
He had 3 at 1 point, and bought EVERYTHING for them including the hard tops/doors/slant back and turret......but he himself is think got overwhelmed and frustrated with not truly figuring out how to weld and make stuff work, so he sold everything off but kept this 2006 M1165. Guess I hammered him enough and caught him at the right time as he needed some bill money quickly. So did the deal last week.
Got it in Scottsdale, took Bell Rd home to stay off the freeway due to tires age and 10 minutes down the road, the front left tire completely disintegrated. So my 2 toddlers learned how to change their first tire....on a HMMWV lol. They had fun, and my 4 year old said when he first saw the truck, "dad, wheres the gun on top?". Hahahahahahah. Told him its college or the turret........college is junk anyway lol. Im a Gunsmith/Manufacturer FFL, so my kids have already seen all the cool "toys" that go on these lol.
Thats awesome youre in Avondale, im just up the road from Garden Lakes.
