Jeepsinker
- 414
- 83
- Dry Creek, Louisiana
My 003A has always ran well for years. Fires right up for everymaintenance run, but now that we needed it after hurricane Laura it won't stay running. Fires up, runs about ten minutes, misses a little sometimes, will bog down, idle way up, settle back to 60hz, then just die. Mind you, this is with no load connected. I think this is an injection pump failure.
It is not the shutoff solenoid shutting it down. I've verified that it does indeed die before the solenoid moves the fuel linkage to the shutoff position.
I have been through the entire fuel system from tank to pump in the past couple days in this oppressive heat to no avail.
Had to go get some little garbage gasoline generator to run the refrigerator and air conditioner. Frustrating to say the least.
