Chainbreaker
- 2,099
- 113
- Oregon
Definitely worth verifying that the proper pumps are installed. The numbers in -24P manual and on my units show the * Facet PN 480517E (stamped on mounting flange). Here's how to locate the P/N.Look at the E2 and E3 electric fuel pumps. Are they EXACTLY the same? Or are they two different types. Look for the part numbers on them. Facet makes several different pumps, that all LOOK the same, but are not. The pump that is suposed to be on the set, is a flow through type. That means when one fails, the other keeps pumping, THROUGH the failed pump. If the pumps are not flow through type pumps, then you get this sort of failure.
* Note the user review below the data sheet in the link above regarding the Facet 480517E
