10 bolt hubs
Tanglewood16137
Mercer PA
Looking to see if there is any interest in 10 bolt hubs to fit a deuce made of good steel would it need smaller lug studs to match front or use big ones so you can use existing hex nuts off old duals. Were hoping to be alot lower than a wicked six made of aluminum. need to know interest before i go to far with it. This way you can just mount hemmtt wheels right on truck no altering rims
Rod
dm22630
42
Front Royal, VA 22630
The front & rear studs on a deuce/5ton are identical.
What you need to do in order to use the 2 piece hemtt rims is put a budcap on the stud, mount the wheel, then use the rear lugs to hold the rim on the budcap.
Tanglewood16137
Mercer PA
what i was pointing toward is using the bigger lug studs like ones on commercial trucks so all you would nee is your outer hex nut so you would just need the 10 for each side up front
Rod
dm22630
42
Ahhh...that would work fine.....I was going to switch mine out w/longer ones when I flipped my hubs, but the $7/each price tag on new studs added up to be almost $500.
If you are going to be making hubs & selling w/studs installed.....go w/the longer ones. BUT....you can save $70/hub if you sell them without.
2cents
ETHOS
Michigan
this is a very good idea, it would be an expensive venture unless someone made a whole bunch of them to drive the per part cost down, i know someone working on the same thing, he has big expensive machines for doing that sort of thing
Defendr200
Reisterstown/MD
So what you're saying is it is possible to use regular hemmt rims on a stock deuce just turning the rims around in the back so that they track right? Also what are budcaps I am new to this whole thing.
ETHOS
Michigan
the deuce has a 6 bolt pattern, the hemmt wheels have a 10 bolt pattern, not interchangable, you either make 10 bolt hubs, or modify the wheels
eldgenb
Spokane WA
I think there will be a lot of interest based on what the pricing comes in at. I know that it would have to come in at or around $300 per side to make it cost effective instead of modding your own or buying pre modded wheels.
