10 Ton winch pics???
OpieNoTool
Boyne City MI
does anybody have pictures of the winch on the front of a 10 ton?? i have one pic. its black and white of a winch on a 10 ton cargo truck. i would like to have some close ups of the winch and how it mounts to the truck. i belive there the 45,000 lb winches
RF202
Does anyone know if this particular winch has a drum clutch which, when disengaged, will allow the drum to freewheel? Additionally, is this the same winch as found on the back of the wreckers ? Unfortunately, those have to be fed out under engine power.
P.S. - You can always depend on Bjorn to bring out the real facts, pics and --- the research ! (Thanks, Bjorn)
Thanks,
John
AMGeneral
115
Connelly Springs, NC
I don't believe it has a drum clutch,on my 123A1C it is power in/out only as is the rear winch on the M62,M543,and M816.They are the same winch just different mounting of the level wind and tensioner.
cranetruck
75
Meadows of Dan, Virginia
John, reading the -10, it says to pay out cable manually. The tensioner valve is operated, by soldier B, I guess, to keep cable taut while pulling the cable out.
If you want to compare, the model number for the M125 front winch is Garwood M3002680. Drum dia is 7 inches and gear reduction is 45:1.
As usual, at your service,
OpieNoTool
Boyne City MI
my rear drag winch on my wrecker the sprocket is on the opposite side than the one in the technical drawing. i thought they were the same too the reason i wanted to see pics is because i have an extra 45,000lb drag winch of a wrecker and was thinking of mounting it on the front of my m543 because its missing the front winch and i hate to see it just sit there, plus who else has one like it :lol: . the only problem i have with it is there is no way to free spool it and i dont always have a second person with me. i know it would be alot of work but i have time.
jeli
Stillwater, MN
You must have arms of iron. Just pulling the cable from the rear wrecker winch wore me out. I don't think you'd get too far. We'd free spool with an M880.
