1008 drifting on acel and decel
Sarge29
Saluda, SC
OK, I just finished putting a set of 36x12.5x16.5 H1 bias tires on my truck. I used spacers on all 4 corners. At this time I have not lifted the truck but a 2 inch lift is in the works. I have a slight rub on the left front and a slight rub on the right rear on the front axle and the rear is clear. If the truck is level it does not rub but if it is twisted a little it does. I couldn't wait a week to get the U-bolts to lift the truck before the test drive, so I took off.:driver: After getting up a little speed then letting off the accelerator the truck seems to drift or move and the same thing when I step on it. I have checked all of the mounts on the engine and trans but everything seems to be good. aua What am I missing? What has everyone done to balance these square tires?
Cucvnut
51
Carver, Oregon
bias play tires go out of round if they are not used and have the weight of a h1 on them or any other vehicle. so the tires might not be roound like a radial tire and that might be what you are noticeing
1,814
I had the same exact issues on my stock M1008. As it turns out, the RR tire was the issue. Start moving some tires around until the issues recedes.
Sarge29
Saluda, SC
OK, I will work on getting the tires sized the same on each axle.
SPECIALTYLC - What do you think is going on with the Detroit locker?
ryan77
56
Cary IL
I had that happen on my 87 civilian blazer, week later the rear end blew... Take the cover off and check the rear end..
1stDeuce
15
Farmington, NM
Check tire sizes first. If the circumferences are different, the locker will make the truck pull toward the smaller tire on accel and toward the larger one on decel. If it didn't do this before tires, start there.
C
Barrman
1,598
Giddings, Texas
I think what they are referring to is how a locker will make a truck handle different than a non locked vehicle. I have a locker in the back of my 396 powered M715. The less air pressure in the 39" tall XZL tires, the more I can steer with the throttle. It is just a side effect of a locker. Learn to anticipate a pull to the right on acceleration and a pull to the left when you let off. The shorter the wheel base, the more dramatic the pull. Put a trailer on there and then drive in the rain. You won't do it twice.
stump
Henderson nc
check the u bolts on the front and rear. check the hub bearings and for brake drag. also front lifting blocks are not legal for road use in some states. Just some things to look at good luck.
Sarge29
Saluda, SC
Thanks for all the help. What I found was the rear tires were different sizes. I measured the OD of the rear tires and there was almost 1/2 inch difference. I pulled all 4 and matched up a set for the rear and adjusted the air pressure to 35 in the left rear and 33 in the right and got them to measure out the same. Done the same for the front, then had another test drive :grin: The problem went away [thumbzup] Now just gotta get the longer u-bolts and put in the zero rates and finish the 2 inch lift and that should take care of the tire rub. Again Thanks for the help.
