1009 Rear window stuck in down position
2AForever
14
Fort Worth Texas
The handle is engaged moves slightly up and down bout an inch or so, but will not close.
The access panel is off and I’m stumped at how to get the glass outa the way and find/fix the problem.
thx in advance
Valor
192
Apple Valley, Ca.
thx in advance
If you can get to the bottom of the glass, I think there are 4 bolts, 2 on each side that hold the glass in. Take those bolts off and then slide the glass out with the tailgate down. Good luck
cucvrus
9,625
Jonestown Pennsylvania
Can you reach in and get a tug on the bottom of the sash and get someone else to attempt to crank the window up? I think you have a regulator that has disengaged or has bad teeth in the gears of the regulator. They are easy to work on and replace but keeping them oiled and greased is key to the longevity of them. Also getting the side runs, bottom sash roller guides free of crud, clean and greased and oiled will help a lot. Spraying WD or CRC will have no effect. may as well pour water on the parts. Chassis grease and motor oil go a long way to keep them old antiques moving. Good Luck and Be Safe.
Indyharleyguy
61
Carmel IN
Sounds like mine has the same problem. I took the cover panel off and found a lever/guide was catching on the piece holding the glass at the bottom of the glass. Tried to bend it back in and only kinda helped. I have a new regulator but didn't know how to replace it. Anybody know of a youtube guide or point us to a thread in here?
2AForever
14
Fort Worth Texas
This Video will be helpful IMO
WWRD99
1,367
York Pa
I have an old new stock regulator for a manual rear window cucv m1009 for sale if you are interested?
Man I need one of those!! Got the 86 blazer ..spring sprung and the teeth eaten gone!!! What's the protocol on getting it!!
Sent from my SM-G955U using Tapatalk
