- 1,394
- 177
- 63
- Frisco Texas
Since my surge brake system was shot, I bought $250 set of electric Dexter brakes, with parking brake lever. I went on info given to me by ... I forget. Maybe eTrailer? Anyway ... bad info.
They fit, but wouldn’t work. Probably because I didn’t understand how they worked. The original drums are made for hydraulic brakes, and they don’t have the smooth outer face needed for electric brakes.
So, now I’m $250 into a job that looks like an empty money pit. Can’t send brakes back because they are pretty “used”. Still want brakes, so I need new drums.
In researching the drums, I see that the only drum/hubs I can find, that will fit the 1.312” outer spindle OD, is a Dexter 9k axle. They run over $1k a pair. Nope.
Every other 8x6.5 drum I find has a 1.25” outer bearing ID. (All the inner bearings are 1.75 on every drum I saw, the 101A2 is as well)
What now ...
1. They sell complete axle kits, w/brakes. $400 or so. Maybe I could get them to subtract the brakes. Still, more $ than I wanted to spend.
2. I can get 2 drums for $200, but the outer race pocket only accepts the smaller 1.25” bearing size.
So, could I get a drum milled out to accept the proper race so I can use the outer bearing that fits the 101A2 spindle?
What now ...
