1028 with nv4500
southdave
ripley, oh/TDY Lordstown,Oh
I was home, and decided to drive the 1028 a bit after my filter relocation.
I notice when I stopped and release the clutch at a stop sign ect.. my locker seemed kicked in?? would that happen,can it be adjusted in some fashion it kind of annoying with the clunkikng and chrepping and not to ment all the fish tailing when it rains.
spicergear
29
Millerstown, PA
That's how the locker works. Driveshaft input makes it do it's thing. If that's a Detroit it is especially true. You can learn to live with it or spend the $$$ to swap out the carrier for an Auburn style or clutch style locker as opposed to more notchy detroits or ratchet styles.
SPCWarning
11
Stonewall, MS
Lube?
Nice looking truck! Have you changed your diff gear lube? Different locker manufacturers recommend certain types of lube for their setup. With the correct lube it will quiet down (some), and definitely run cooler. This will also help with the proper operation of the locker.
