1031 contact maintenance truck
SmokeyDod
Easley, SC
Glad they helped you. Any type 220v welder say from Lowe's (lincoln 225) Remember the air compressor that comes and wired to this unit is running off of 220v 3ph. Just set your welder in the truck and plug it into the 220v "single phase" outlet as most of them are 1ph (single phase). Should work fine. Smokey
1956_4x4
Crestview, Florida
If you are going to plug that welder into the single phase outlet, pay attention to the amperage rating of the unit. The 208 single phase on the panel is limited to 15 amps and this really limits what you can use it to operate. I run a plasma cutter out of mine and I'm limited to cutting thin metal. As far as a welder, I just run a small mig unit and it works fine.
Smitty
