1083 AO Transmission fan
chucky
18,745
TN .
I took my truck out for a spin around town the other day ! Hills /stop and go traffic and the main engine fan was starting to cycle and it got me to thinking how could i test the trans fan mounted on the frame to make sure its working correctly ?????
chucky
18,745
TN .
It’s unlikely you will ever see those fans come on. Just have to find the sensor and unplug it I’m sure. They normally default to a failure=on mode.
OK i cant say that ive ever heard it come on i thought maybe there was a way to jump a wire or something simple to cycle them ! Thanks
chucky
18,745
TN .
Oh and 2 other questions ! did you ever put a price on the bent up a1r grill you said you had ? And are you going to oct 6/7/8/9 tn. rally ?
chucky
18,745
TN .
The trans fans should come on with the engine fan. I can look it up this afternoon but pretty sure aux cooling relay works in concert with fan control solenoid valve...
I was driving when the main engine fan came on so i dont know if the trans fans came on or not and do you know at what temp the engine fan is supposed to come on the water temp gauge ?
chucky
18,745
TN .
I think i would like a rocker switch on the dash to turn them on when i wanted but in the off pos they would work normally
Ronmar
6,619
Port angeles wa
No problem. The thing with the fans is that they are inverse control. They provide power to keep the aux cooler relay and solenoid energized, which keeps the fans off. The thermal switch is normally closed providing the 24V and opens at 205F to de-energize the engine fan control solenoid and relay K15. CB22 provides the power for the fan solenoid, K15 aux cooler relay and the ether system.
To test your aux fans, simply pull CB22 and turn on the main switch. This will keep k15 from energizing and the aux fans should spool up as soon as 24V ignition power is applied. If they don’t, check that K15 is a 5 pin relay, and that power is making it thru CB68 which provides the fan motor power…
Unless you are pulling a real heavy load, the aux coolers may not see much play anyway. The fans will cycle with the engine fan, but unless the trans oil is getting real hot, the thermal diverter is probably not sending much oil to them…
