1088 will not shift, mph gauge not working
Sweep
Central Ar
Our 1088 tanker will not shift above second. Can’t shift manually with the buttons either. Mph gauge is not working. It jumps when I put it in reverse. Everything has worked until now. Only work I have done lately is delete the trailer brake valves in the cab and charged two batteries yesterday. Anybody have any quick tips before I dig into the endless tm’s?
Sweep
Central Ar
Also changed the thermostat today.
simp5782
Feo, Fuerte y Formal
9,285
Mason, TN
Bad output speed sensor will default it to 1st gear. Pull the codes on the programmer and see what it says.
Sweep
Central Ar
Pull the codes?
The truck does not default to 1st. It goes into 2nd when put into drive. I can shift down to 1st and back to 2nd. How do I pull the codes?
Suprman
663
Stratford/Connecticut
The truck starts in second. First is low range. Check the codes. Could be speed sensor. It’s on the underside of the trans and is an over the counter allison part.
Sweep
Central Ar
Thanks for the replies. I got codes from the tranny d1 tranny oil to high and d2 tranny oil sensor failed to high. Can one check the speed sensor for resistance to see if it’s bad?
Suprman
663
No it’s a mag pickup. Did you check the trans fluid level? Running warm in neutral. You could have a wiring harness issue. I see that a lot. You should visually inspect the harness it comes out behind the grill drivers sid hump follows drivers side frame rail and then crosses over trans and mates with a pigtail coming off the trans passenger side. Look for dry cracked wiring. Is this a new problem or did you get the truck this way?
Sweep
Central Ar
So I put a few things together. The truck stop engine light has been coming on intermittently. I thought it was running a little warm. At 200 the light would come on. It would never get above 210 as it would drop down when the fan would come on. I changed the thermostat to be safe. Now I’m thinking that the trans speed sensor and the trans temp sensor in the transmission may have failed due to the cooler fans never coming on (I’ve never heard them come on). The stop engine was light was coming on for the transmission not the engine. The codes I got from the transmission were transmission fluid to hot and transmission temp sensor failed to hot. Opinions?
Suprman
663
Just because the gage said 200 dosnt mean temps couldnt be higher elsewhere. Or the gage could be wrong. The stop
warning is there for a reason. Maybe you overheated the trans. Maybe the pump wasnt circulating the trans fluid properly. I think at this point its an issue that would be best addressed by an Allison dealer.
Sweep
Central Ar
Ok thanks. I pulled the trouble shooting guide for that one and the speed sensor. I’m going to check resistance on these and see. It’s going to the dealer this week anyway, but need to be able to drive it if possible.
Suprman
663
I woudnt drive it like that. Could cause more damage. The speed sender usually causes a jittery speedo and erratic shifting when bad. Something else going on.
