- 3,923
- 76
- 48
- Comfort, Texas
I am about to reassemble my 10K front winch. I have installed all new gaskets and seals and everything is cleaned up and painted. Unfortunately, I have slept some since I took it apart and have a few questions. The TM list the assembly steps but I am unclear on two items.
First, can you give me a hint on the best way install the thrust ring closest to the end frame housing and the drum sliding clutch when assembling these parts on the drum shaft? Particularly, how do you fasten the drum sliding clutch to the shifter fork. I believe the round tabs on the shifter fork go into the slot on the sliding clutch but I am not sure the best way to get all these together.
Second, at the clutch end of the drum there is a slotted plug. Can you tell me what that is for?
