shadow
- 1
- 18
- Cedar Rapids, Iowa
DR said I would need a voltage regulator. I tried looking at Saturn surplus but they show Sold-Out and that there are 2 differant ones. Does anyone know a ball park price on these and where I could locate one?
Also, where could I find a manual online or a book for this genset? It is stamped TM 5-6115-275-14&24p on the plate but I can't find a site that lists this number.
I am hoping to use this genset to power my welder and an air compressor I need to pickup that is 240V. I don't know if it is 1 or 3 phase so that is an issue to figure out. I can't get a reply from hydrovane to find out ANY info on our unit. Would anyone by chance on here know anything about them? weight/psi/cfm/life of unit?
all I know is:
Manufacturer: HYDROVANE
Model: 120CK
Serial Number: 20hv329815
I found a pic online of one like mine but the one pictured is in bad shape, missing parts. Mine is 10 times nicer and is still hooked up ready to run.
http://www.flsales.com/photos/fullsize/TAG7216.jpg
If i was to describe it I would say the time it takes for the small portable compressor of 3-5 gallons to max out, it would take the hydrovane about 3 or 4 seconds to make the same. We used it for our sand/media blasting for cars, large & small cabnet blasting in another room, room air vaccume, and the air supply line for the operator all at the same time and never had a problem with it. It was hooked to a tank that is about as long as the unit is and I'm not sure of the gallon size. Maybe 100 or so.
Any help would be greatly appreciated.
all I know is:
Model: 120CK
I feel I am getting close to getting this running.
