- 1,831
- 963
- 113
- Paris KY
Ok I have searched and read and searched and read and searched and read some more and still cannot find answers.
I love my custom 11.00/20 wheels and NDT tires for highway use. However for off road use there just isn't enough room under my fenders for articulation. So I plan to put together a set of 12-bolt beadlocks with HMMWV take-off tires to run during hunting season.
Questions -
1.)- I will not use the run-flats, however I do want an insert to facilitate reducing tire pressure for increased off-road traction. Is the PVC insert from Trail Worthy Fab the only choice, or is there a more economical insert available?
2.) - To run the 12-bolt wheels I will need a set of 2" spacers. I would prefer steel instead of aluminum. Where is the best place to purchase steel spacers?
3.) - Should I use LocTite on the bolt threads that hold the spacer to the wheel? Red or Blue LocTite?
4.) - The military valve stem is vulnerable in rocky terrain. I don't like rock guards, but I would like to keep a couple spare valve stems on hand. Where is the best place to purchase new HMMWV valve stems?
5.) - I plan to use Dyna Beads to balance each tire/wheel. The quantity of Dyna Beads is determined by the combined weight of the assembled tire and wheel. What is the weight of the 12-bolt wheel and HMMWV tire? I will add to this the weight of the beadlock, valve stem, and lug nuts to determine how much Dyna Beads to order.
Thanks in advance for answers.
Questions -
