My first idea was to use converters on each wire so I wasn't pulling all the power off the E pin, but I found that the converters don't turn on/off fast enough for a turn signal flash. I tried it on incandescent trailer lights that pull decent power so with LED's the turn signal might not even flash if the converter still has residual power long enough to keep them bright over the flash cycle. I'm also thinking it might shorten the life of the converter if it does a lot on on/off switching but I'm not 100% on that.I also pull a trailer with my Humvee, I did install the led bulbs, but they don't seem as bright, and I want to try the LED trailer lights, but they are not available for the 14 V
So I was going to try one of these, I would need three of them, one for each brake/signal and one for the parking and marker lights
https://www.amazon.com/Nextrox-Conv..._rd_t=40701&psc=1&refRID=54YCCT3TJDTFE1HK6F6P
These are the lights I want to install
https://www.superbrightleds.com/mor...MIzaGmrp743gIVm7jACh1fAAE6EAYYBSABEgLV6vD_BwE
I'm happy with just pulling a 12 volt off the back battery and routing through three relays. It is very clean and neat when installed. You can keep the NATO plug in place and just splice into the needed 24 volt signal wires, or tuck it away and replace it with a standard 7 pin or even 4 pin. If using a brake controller, that would need to be wired through the 12 volt battery anyway, then fed back to the pin on the 7 plug so that's no big deal.My first idea was to use converters on each wire so I wasn't pulling all the power off the E pin, but I found that the converters don't turn on/off fast enough for a turn signal flash. I tried it on incandescent trailer lights that pull descent power so with LED's the turn signal might not even flash if the converter still has residual power long enough to keep them bright over the flash cycle. I'm also thinking it might shorten the life of the converter if it does a lot on on/off switching but I'm not 100% on that.
