CloverFireCo
- 0
- 0
- Heckscherville, PA
Hi guys,
Our M813A fire/brush truck project is coming along and I have some questions about adding 12 volt equipment to the truck.
If I understand all this correctly I have 3 choices for adding a 12 volt system to the truck.
1. pull 12 volts from the first battery on the 24 volt system, this seems undesirable to me as this can lead to issues with uneven charging in the 24 volt set-up.
2. I can make a bunch of modifications and add a 12 volt alternator to the engine, this seems like a pain but will give me a system that should work well for the long haul.
3. I can add a 24 to 12 volt converter which was the choice I was going to use until I ran into a few snags.
When looking for a 24 to 12 converter I found locally a reasonably priced 20 amp unit. Then I started looking at my amp draw for the equipment I was putting on and got the impression that this isn't going to work.
The radio will pull 37 amps when you transmit, this doesn't count the strobe light-bar on the roof that pulls about 10 amps when all strobes are going, the take-down and alley lights I did not check yet. Long story short I am adding much more amp draw than a 20 amp unit can put out. Most of the items will be somewhat intermittent but when first responding to a call all the emergency lights and the radio will need to work.
Ok, so adding to my plan, I thought maybe this would be a solution. If I put two 12 volt batteries on the truck, wire all the 12 volt equipment with dedicated grounds back to these batteries they should be able to take the shock load of radio and the converter would work like an alternator charging them back up when I draw them down. If this will work can I put two or more 20 amp converters and end up with 40 or more amps of charging power to handle the amp draw.
Keep in mind that most GM alternators for cars were around 60amps or so and on a piece of fire apparatus is usually above 130 amp alternator.
Looking for thoughts on this as I would like to have this truck ready for service in the next two weeks, Fall brush fire season is coming up quick and I hate walking up the mountain to the fire.
Thanks in advance for any thoughts or ideas
Chris K.
President
Clover Fire Co.
Heckscherville
PS. If I can get it ready in time for the rally at Rausch Creek, we will be there, We are located 3 exits north of the Tremont exit on I 81.
PSS. I am looking for a winch for the front of this truck, If anybody might have one sitting around, all donations accepted
otherwise tell me how much you want for it.
Chris K.
President
Clover Fire Co.
Heckscherville
