12K half shaft part numbers??
Mogman
10,504
Papalote, TX
Sorry if this is redundant, I did search and did not find the answers.
SO for 12K hubs and vented rotors the half shafts are
LF= 2520014214588, RCSK17028-3
RF= 2520014231947, RCSK17028-2
REAR= 2520014214589, RCSK17028-1
Also the 12K uses the same boot in and out?
These would be A2 shafts YES??
Mogman
10,504
Papalote, TX
I found it all in the TM's
I did too, that is where I got the numbers, BUT there are evidently MORE that one set of 12K half shafts, some with vented brake rotors and some with solid rotors, the TM did not specify which these are, I just want to make sure before I plop down a large amount of cash, but THANKS for your HELPFUL input,,,
Coug
4,769
Olympia/WA
A2 are vented rotors. The part numbers for them are the ones in the standard parts manual, not the ECV parts manual. None of the others will be in TM 9-2320-280-24P (books one and 2)
Unless you have an ECV or REV truck then that's where the numbers would be.
