Stalwart
- 33
- 48
- Redmond, WA
I've decided to go a different route. Mounting 2 new one wire alternators on the HEMTT's 8V92 seemed kinda like a pain in the butt. I didn't like the idea of a DC-DC converter, I have a dead one of those already and you are limited to the capacity of the converter. I've decided to go the route that is used on many 24V motor coaches, a battery equalizer.
Initially they seemed like the most expensive option, I've seen them priced above $1000.00 The benefits are that there are only 3 connections, ground, 12V and 24V; they continuously balance the batteries within .05V, and they are small and all weather units.
I kept looking on FleaBay and I was able to snag a new latest 100A model for $200. Now I'll be able to run any 12V load I want, the batteries will discharge and charge together and I only have to make brackets for one civilian 1 wire alternator of around 100A capacity.
I'll of course be using circuit breakers and it will give me an excuse to make up all new, soldered and heat shrunk #0000 battery cables.
I've also decided to put the failing and overheating electronic blackout light issue to bed. I'm gonna make that switch do nothing but control relays, my last one burnt down 4 IC chips and my truck only has LED lights. We'll see if it can burn itself up switching less .5A and yes, I'll be using relays with a diodes to protect the IC's.
