12V Clarification / Question
cg25713
51
New York
I have a 200A dual voltage alternator with a voltage regulator. Do I still need to install a 24/12v converter to run a stereo and a dome light?
TOBASH
3,010
Brooklyn, NY
No. If you have a 4 speed tranny you should be all set with what is on your rig.
cg25713
51
New York
So I can connect a 12V fuse block directly? If so, where? To rear battery pos and neg? Others have said a converter is preferable due to a battery imbalance and possibly running 2nd battery down.
Coug
4,086
Olympia/WA
You can get away with wiring things straight to the rear battery as long as the amount of load doesn't get too high.
For the older trucks with a 60 amp generator you'd definitely want a converter due to imbalance, but the 200 amp is a 24/12 output, and provides up to 50 amps of charging to the rear battery at 12V. Part of that is being used by the transmission control computer, so don't put more than about 30-40 amps of load on the rear battery. More than that and you really will want a converter.
Coug
4,086
Olympia/WA
if you plan to use it a lot with the engine off then the converter is also a better idea to keep from running down the rear battery, but if your batteries are in good shape and you aren't running the stereo full blast for hours on end or leaving the dome light on for days at a time it shouldn't be an issue
cg25713
51
New York
So I could connect the fuse block below directly to the rear battery pos and neg and run a stereo, light etc. from that as long as the amp draw is relatively low?
If yes, what gauge wire would you suggest I use? I plan to mount the fuse block in the small space next to the battery compartment. Thank you.
papakb
1,186
San Jose, Ca
To answer your question I would use 8 AWG wire at the minimum to the fuse block and 4 gauge if you plan on installing anything that draws more then 20 amps.
BTW, that depth sounder fuse could be used for an oil level sensor!
Coug
4,086
Olympia/WA
What wire size you run depends on what you are planning to power/how much draw. That also determines what size fuse.
Simple wire chart here:
For automotive applications, 14 gauge is usually good for 15 amps, 12 gauge for 20 amps, 10 gauge for 30 amps. I like to just run the Prestolite 14 gauge military cable for anything needing 15 amps or less. (keep in mind these are shorter runs, for longer lengths you need to go up in size)
You can always run a larger wire (smaller number size) than you need, but you never run a smaller one. Same goes for fuses. You can run any size fuse with a lower rating than the wire is good for safely.
For the above fuse block, the manufacturer rates it for 100 amps in and max 30 per circuit, so it depends on how far away from the battery it is for what size wire, as you want to keep the amount of voltage lost through the wires to a minimum (usually 2% or less). According to the chart I linked above, you would want minimum of 8 gauge wire to the fuse block if under 7 feet wire, and 6 or 4 if more than that. Remember also that's 7 feet total wire, which means 3.5 feet of positive wire and 3.5 feet of negative wire, not 7 feet of each.
As most circuits will end up grounding to the chassis or body, you only have to count the wire length to get to the grounding point, not all the way back to the battery (unless you're grounding everything to the battery negative terminal)
specs for the above fuse block:
