12v Deep Cycle Battery Set-up for Camper on 24v '68 M35A2
n1vbn
derry,NH
Just do like most drivers do add about 5 or 6 rubber bands (your local postman is the best supply) around the sunvisor and PRESTO!!! Instant cigarette, receipt, pencil whatever holder.
Another good spot is the gearshift lever, I.ve seen other drivers use a hose clamp to clamp a soup can to the gearshift to hold items. KISS principle applies here.
reblawyer
Tupelo, ms
I'm taking a look at a 10 amp 24 to 12 voltage reducer to put a charge on a seperate 12 volt battery to run the 12 volt items. Seems pretty simple right, I'll let you all know what goes wrong first.
Rattlehead
Michigan
You can use a 24 to 12 converter to power things directly, but they would not do so well to maintain a battery. Ideally, a battery should be brought to around 14.5v, held there for 30 min or until the amperage draw is fairly low to be fully charged. Then the voltage can be dropped back to about 13.5v and held there indefinitely. If you discharge a battery and then only put back in say, 13v, it will never fully recharge and lead to sulfation.
