12V illum. switch on 24V system?
1,193
Post #2 suggested that.
tim292stro
40
S.F. Bay Area/California
Tim292stro- I took a switch apart but no resistor inside. Once I have the correct resistor, how do I wire it in? The terminals on the switches are labeled "power", "acc", "ground".
For future reference if you have this type of LED toggle switch:
the resistor is in the lever with the LED.
If you have this type:
the LED and resistor is in the base.
If you want to avoid resistors with LEDs in a toggle completely, you can make an LED illuminated toggle into a "multi-volt" switch (5-30V) by using a current limiting diode. This is a small self-contained regulator that will only allow the specified current through - it does this by adjusting its equivalent DC resistance.
ke5eua
41
Baton Rouge (Central), LA
Ohm's Law
V(E)=I/R
Desired Voltage (Energy)= 12v
Resistance used = 1000
That means the current draw of the light would is 12mA or 0.012A. That sound like an led light to me, which means it most liekly would have worked on 24v to start with
All you had to do was provide the current draw or the model of the switch you were using and anyone of us would have provided you with the correct answer with a crayola drawing, lol
Woodsplinter
Phoenix/AZ
Thanks Mike! I didn't know the current draw until I went back to the store and decided to try the 12V route again. I tried the same switch before with some led work lights that only pulled 2 amps total. The light burned out in about two months but the switch continued working.
I was really hoping to find 24V switches and avoid using resistors altogether.
ke5eua
41
Ahh, yeah having the specs on the switches helps when determining current draw and voltage range.
It's no biggie, glad you got it all sorted out.
