12V LMTV Headlights
73m819
323
gainesville, ga.
I converted a pair of civi lights by splicing the wires of the light socket to military ends, works great and a lot cheaper.
PowerstrokeNC
Greensboro, NC
Funny you say that, that was my next move cut off military connectors from old light add spade terminals on cut off end and badda bing, can use a regular 7". I think I will do this and stop trying to worry about original part, thanks
Oxyacetylene
179
Stoneville, NC
I ordered a kit from Those Military Guys. The low beams are really dim. Not sure if I have a grounding issue, but definitely getting the right voltage. It is an aftermarket 7" housing with adapters made like you guys are describing. Try to get DOT approved glass lens housings. I think I might try a set of Silverstar bulbs in these to see if that makes the low beam usable. Of course, I may have a grounding issue or relay issue or something that is restricting the current flow, but I haven't taken the time to troubleshoot it.
ZiggyO
444
Nebraska
I have the correct 12 volt LED headlights for the LMTV series trucks...... check my classified or pm me.......
Z
