Which would be considered the lower alternator
Yes... inquiring minds want to know
I think B-o-T was referring to the M1010 setup.
Most CUCVs use the Drivers side alternator for 12v, and the pass side for the 'additional voltage' needed to make the 24v.
If you look at my avatar, you see I have a Federal Jetstream lightbar on my truck. It is tied to the front battery.
For your winch, I would suggest maybe adding a battery in parallel to the front battery. (depending on how much you intend to actually use the winch, and for how long) Providing additional reserve capacity on the 12v system.
