thordehr
- 0
- 0
- Los Angeles, CA
Is there any reason you couldn't get useable 12V by just tapping across either one of the batteries? The batteries as they sit in the truck are in parallel giving 24V from one end to the other, but they're still 12V across either set of terminals.
Is there any huge issue with a battery being more than the other? The draw would be minimal, phone charger, GPS, maybe an intercom? Maybe the loads could be evened out by putting some 12V loads across one battery and some across the other battery?
Ok, how about this for a second idea?!... Just thought of this while writing. Since batteries in series are (depending on the health of the batteries) evenly loaded.
Keeping that in mind, how about with the batteries still hooked up in series making the 24V, then also taking the positives from both batteries to one point. And also taking the negatives from both batteries to another point. This would be Ubersimple to setup.
This would leave you with a 12V source with a floating ground. You could not ground to the chassis but would have to bring all the 12V items to those two points positive and negative. Seems this would inherently even the load between the batteries and isolate the 24V and 12V systems.
Any glaring reasons either one of these ideas couldn't be done?
Barring that..... how about a third idea: 23 amps of 12V power for less than $100.
Samlex America SDC-23 20 Amp 24v DC to 12v DC Converter
