1400x20s on M813
FM5332FF
Labelle, FL
M215 What kind of lights are those mounted in your front bumper? APC? I thought of doing the same with mine. Your Truck Looks Great. [thumbzup]
green goat
Fort Worth, TX.
I like the look of the hubs flipped on your truck and have been thinking of trying it on my 925a2 but the hub is shaped different and not sure if it will work, anyone here tried it?
M920
30
chama/nm
I agree, it was a lot of work, but it was what I wanted. Flipping the rear hubs allows the rims to all face the same way, bolts out with the hubs flush with the face of the rims.
I think it was well worth flipping the hubs....The truck looks awesome that way! :beer:
Do they track the same that way?
Soni
cmayer85
Karl
i agree with jwaller, i think it is way too much work for no benefit to me,with that being said im a firm believer that its your truck to do with as you please. looks great singled out [thumbzup]
Bearpaws
Southern Arizona
Awesome looking truck. Very clean look with the hubs flipped. I don't know if this is the same with the MVs ? The commercial " Ten Wheelers" that ran the wide super singles on the steer axle had a increased toe adjustment to solve the wondering ride. I read that 920 runs 22.5s on his big ol truck. Might find out what he did. The speeds he can hit sure must be right. Seem to remember 3/8" to 1/2"
toe. You might get your tape measure out and check what you have. If all your componets on your steering are in good order you might increase what you have for toe in slightly and see if this helps. And of coarse watch for increased wear. The tires looked to be rounded at the shoulders. Might be the characteristic of these to do this.
spicergear
Millerstown, PA
Nice look with the hubs out! Lends itself to a more Eastern European truck look as it seems lots of them are singled out from the getgo and have a similar look. Looks great!
JWaller or others: When the five ton hubs are left flipped in is the track width the same front and rear? I know on the deuces it puts the rear wider than the front.
sigo
Lieutenant Colonel
441
Leavenworth, KS
Great look on that 813!
Without hub flipping is any other modification necessary to put HEMTT rims on an 809 truck? Someone mentioned new lug nuts? I'm looking to single out my 813 with 14s as well and I thought I needed the newer 5 ton rims to do it with no mods, just get the 14s put on some HEMTT rims, then a wheel change on the the truck, swapping the old split rims and 11.00 NDTs for the new HEMTT rims and 14.00s. M215 made it look easy with HEMTT rims. :mrgreen:
Any speed increase with the 14s? I'm happy running about 50mph with my truck, they werent made for much more than that, but I'm curious if the 14s change the top speed much while keeping the engine at a happy rpm.
dlc
Postville Iowa
Hey you wheels guys!
My fire dept. Just got a set of used 14.00 X 20 wheels to put on our 5ton we use to haul water with. Problem is most of the wheels leak air. I personally am not familiar with this rim system. is it just a matter of braking them all down and then reinflating or is it more then that? what's your thought? Thanks
M813rc
3,760
Near Austin, Texas
My M813 (governed 2100rpm) will run around 65 on 14.00's. Hard to know exactly, because my speedometer only goes to 60..:wink: However, at that speed I feel a bit like a missile, and I don't like that.
I have found that the truck "likes" 57mph indicated, as in, if I drive on the highway and don't look at the gauge a lot, it will almost always be at 57 when I do. The truck and I are both quite comfortable cruising at 57, and will do so without a hiccup for several hours at a time.
That said, when I go long distances it is usually to a show and in company with Deuces, so cruise ends up being around 52mph. (Or 48mph if one of our members is in the column, he has an 'anchor' deuce..:lol:)
Cheers
M215
Spotsylvania, Virginia
holding air
DLC, not sure what type of rims you are using. 5 ton super singles & HEMIT rims are bolt together tubeless. Leaking can occur at the large O-ring or the valve stem. Most likely the O-ring. These can be converted to tube & flap type but the rim has to be modified.
cbvet
20
Northwest (Knox) Indiana
I had to replace a bad "O" ring in one of my wheels. Got the ring from Memphis.
It was a lot of work, but not terrible. I have an old forklift which helped a lot. The beadlock was a pain too, but I'd do it again before I'd pay someone else.
