151 a1
fland 244
Kingston NY
what is minimum fuel pressure this truck will run on..
how to test temperature gauge
how to ID the little metal tags on the wires
truck hasn't run in 30 years it did run spraying gas in carb for a few minutes..
Ok got it running.. compression at 119-120 all cylinders
back of exhaust maafold glows red in 3 min. of run time
Why
joel
9
sioux falls,sd
I think to test temp gauge--take wire off sending unit--ground it to block, the gauge should go to hot--of course this is with the key on/engine running--I don't say with key just on as that might damage something if you have electronic ignition?The TM has the info for everything you ask
