428gearhead
- 52
- 13
- Martinsburg WV
I was looking for a way to load test my MEP802A and had an idea:
I happened to have an old heat pump air handler laying around. The air handler has a 15KW heating coil pack installed for aux heat. Now, 15KW is too much for the 802A, however the coil pack consists of 3 separate 5KW coils switched by 24v relays. The blower motor has 3 speeds as well.... perfect.
I hard wired one of the 5kw coils and the motor for now. It put a 90% load on the 802A.
In the future, I will utilize the 24v relays controlled with switches, and same for the blower motor. The case will be shortened, screens installed and will roll on a set of casters. I will update on the finished product when complete.
