15KW TQG MEP-804A & MEP-804B manuals and info
LuckeyD
388
Vilseck, Germany
Good day: 15KW TQG info all I needed for 20 years. Was designed for small 3 phase uses. Requires a bit of work to work on today's high electrical use homes that are 120/240VAC instead of changing to a 3 phase house entrance because of heat pumps and electrical heating.
Issues: faulty fuel, so use clean DF2. Fan belt stretches. causes squealing. Oil filter mounting, injector pump and solenoid issues, K1, Mag Pickup and A5 issues. Voltage regulator issues. Load terminal issues. Once in order, this gen will serve you well. Service it.
For those who do not know about how the Army TM's are laid out:
1. LO is the Lubrication order. It tells you when, how and with what, about how to service the Equipment.
2. TM is for Technical Manuals
2a. TM's ending in -12 are the Operators Manual. A must read before trying to operate the Equipment
2b. TM's ending in -24 are the Unit, Direct Support and General Support Maintenance Manuals.
3c. TM's ending in -24P are the Repair Parts Listing for the Unit, Direct Support and General Support Maintenance Manuals.
Thanks to members @juanprado , @kloppk , and anyone else who I might have forgotten for some of this information.
Basic TM's
LO 9-6115-643-12 dated 2008
TM 9-6115-643-10 dated 2010
TM 9-6115-643-24 dated 2008
TM 9-6115-643-24P dated 2010
Engine TM's
TM 9-2815-254-24 dated 1993 wc# 1 & 2
TM 9-2815-254-24P dated 2010 For the MEP-804A
TM 9-2815-538-24 & P dated 2009 For the MEP-804B
Guyfang
27,284
Burgkunstadt, Germany
Additional Civilian and Military Technical Information.
15 KW Speed Control Adjustment for the Yanmar Engine Document
DRS Digital Document
(The term Digital TQG refers to a TQG generator set that has been modified by replacing the control box with a retrofit control box that adds CAN bus monitoring and control, Modbus monitoring and control, MicroGrid capability, remote start/stop and load dependent start/stop.)
MEP-804A, Wrong Starter
15-60 KW A Model Governor Control Unit (A5 GCU) Adjustment
15-60 KW Diode Ring Information
15 KW MEP-804B Battery Charging Issue
Guyfang
27,284
P.S. Magazine Articles
15-60 KW P.S. Magazine Article, dated 2001
Volt Regulator differences
The enclosed list shows you the Part Numbers and NSNs for the two Electronic Governing Systems for the MEP-804A and MEP-804B Generators. The systems are made by LIBBY and TRC. The parts can NOT be mixed. Failure to heed this warning can lead to equipment damage according to the TM 9-6115-643-24. If you need to order a part from this list, insure that all other parts in your set are from the same manufacturer.
