- 179
- 19
- 28
- Gilroy, CA
Picked up a set of hemtt wheels and 1600 michelins for the 916, but have a few questions before I can get the tires / wheels mounted up.
1) What are the correct valve stems to run? Looks like there are two styles of hemtt valve stems. An old one with two valve cores, and a newer one with a single. Are they both easy to check pressure / fill up when flipped in the rear? Anyone have a good source for those?
2) Need to get some longer wheel studs in the front, but have had no luck at the local truck shops. Its way bigger than anything they have in catalogs. Can anyone give me a part number, or source?
3) This interference seems pretty wonky... What have guys been doing?
![IMG_6304.JPG IMG_6304.JPG](https://www.steelsoldiers.com/data/attachments/384/384295-698930d685edf2e1d89b2b4943e68036.jpg)
![IMG_6306.jpg IMG_6306.jpg](https://www.steelsoldiers.com/data/attachments/384/384296-c6190392ac2f877b61a74ffb6396df2c.jpg)
![IMG_6307.jpg IMG_6307.jpg](https://www.steelsoldiers.com/data/attachments/384/384297-b45e6ca8a3e941a2bd7a974255de5267.jpg)
