  • Thread starter Deleted member 11142
  • Start date
74M35A2
340
Livonia, MI
Hi Derrick, that Honda is an expensive engine. Any chance you can use a belt driven hydro pump on the engine, or a PTO off the trans?
Jbulach
2,402
Sunman Indiana
I second the PTO to drive your pump, maybe check to see if TobyS PTO's for sale will fit your transmission.
D
Guest
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
One of the basic rules of thumb, for hydraulics: http://www.metaris.com/hp-calculator.php
According to that, your Honda motor - with the adequate pump and working at 3000psi, should be able to produce almost 13 GPM.
For reference, the chart below shows the pump specs for the various HEMTT "Material Handling Cranes"...
Your crane may be comparable to the higher cap. M978 and M984 models, and the max. working pressure should be the same for all of them.
Maybe a bit slow, but it will work.
wcuhillbilly
Devils Tower, WY
Any chance of finding one of these sheets for the old 816 crane pump...????? looked in some of the TMs but sorry, I fell asleep and reverse osmosis didn't happen through the drool on the keyboard.....
