18KW Drash Generator Help
Poccur
146
Roanoke, VA
Its my understanding that most of what people call DRASH, is in fact built by another company.
I blame the auction sites for calling any trailer mounted generator/air conditioner a DRASH...
Back in the day the two main players in trailer mounted generator/air conditioners were PowerSystems Intl who sold the GET (Generator Ecu Trailer) and DRASH...PowerSystems was purchased by HDT and continued to compete with DRASH. In the meantime Applied companies made their GETT (Generator ECU Tent Trailer), this is the one you always see on surplus, has red LED display, the fuel lines rot and the fuel rack sticks. I believe that is the one you are referring to.
For some reason the auction sites called all these models DRASH and it stuck.
After all this HDT purchased DRASH so they now sell the GET and DRASH trailers.....As for the Applied trailers, they still show them on their website but I have not seen one deployed in a long time.
20,812
The soldiers are no different. All trailer mounted ECU/Gen sets are "DRASH".
Kinda like Kleenex, Xerox, Coke, or Jeep.
All really are brand names. All have become the thing that people refer to as that "snot paper" or "copying machine" or "caramel colored beverage" or the "four wheel thing to play with in the dirt".
Nixon84
Fort Stewart, Georgia
I have a drash trailer generator that will start and run but will cut back off immediately, so when I open the panel I notice that the K-5 relay light is illuminated. The fuel filter is fine. The good drash that I have don’t have that light illuminated. Can anyone give me some guidance? I’ve attached a photo for viewing as well.
Chance are your relay is bad. Your drash would crank run and shut off because your batteries might no be getting charged. I'm not 100% sure but I had an issue once like that in the field, we jump started it, fired right up then ince removed the jumper cables it died. Tested the DC voltage output at the slave receptacle and it was reading 20.46 volts and dropping. I think that fuse if lit up needs to be replaced according to the TM.
Nixon84
And that's exactly what it was, that K7 fuse is part of that charging system. I swapped it out, tested the output at the Slave receptacle and sure enough it was reading that 28+ vdc, thanks for the input.
