CMP Nut
- 2
- 0
- Windsor Ontario
This is one of my rides. Originally built here in Windsor Ontario it last saw use as a snow plow for a garage up north. Having been abandoned it was brought back to life after 18 months of work. It is powered by the favorite of hot rodders, the legendary Ford V8 flathead. It is right hand drive as designed from British specs. Selective 4 wheel drive with a standard 4 speed trany. With the gas pedal between the clutch and brake it is actually more comfortable to drive with this configuration. With a short wheel base of 101 inches it looks more like a toy when parked on the road. Yes it is a head-turner and is only one of two on the road in Windsor. For those of you in Michigan, I plan on attending a few meets in the Spring and Summer...see you then.
cheers
Mike
cheers
Mike
