njjeeper
- 4
- 8
- Morristown,NJ
This is my first dodge MV so please excuse me if I am missing something obvious. The story on this truck was that it was driven to the field 6 years ago. So, the story is it should run. I drained the bad gas, flushed the lines wih fresh gas and put a few gallons in the tank. When the starter is turning, fuel shoots out of the line to the carb. I removed the odd elbow on the carb so I could see the choke plate and dump gas in if need be. Pulled a few plugs and verified they all spark when it's turning over. All this, and the thing still refuses to run. Gas down the intake only seemd to flood it out. Most times it doesn't even try, other times, it will sputter just a bit. I am trying to start with the choke fully engaged. Batteries are fresh. Any ideas will be much appreciated!!
