1956 M38A1 parts
ebyrd10000
Phelan Ca
Hi
I am new to this site and first time owner of a 1956 M38A1 jeep ..It has had the front fenders cut up a little bit.I would like to restore this jeep back to original. My question is are cj fenders the same as M38a1 fenders? are most of the cj parts the same?
BFR
Rocket Surgeon
2,331
North Georgia
early CJ5 fenders should be the same. a lot of parts from a 5 will work, but that doesn't mean they are the same (what kind of resto are you going for?)
mutt1966
13
Allentown, PA
If you go over to the G503.com site there is a whole section for the M38A1 yes the CJ-5 fenders will work except the left one will need to have 3 holes drilled for the Military blackout light to be mounted. Scott out
1,124
The tub, grille, dash and windshield are all different from CJ5 to M38A1. They will physically work but are not correct. I am not sure about the hood.
There are also many mechanical changes underneath, like the reinforced frame and different spring hangars on the M38A1.
ebyrd10000
Phelan Ca
I am not going for a concourse typr restore just want it to look pretty close to the way it came. I don't ming using a cj fender and drilling the holes and things like that.. just thought some cj parts might be cheaper to buy..
