1969 MEP 10K Generator
jimmr
Hells Canyon, ID-OR border
I have 2ea. 5k's and one 10K. this 10k i got from my neighbor where it's been sitting outside for a few years. I got it running and it sounds fine, it indicates 240vac available but it is not charging the batteries. I believe it is the rectifier that has a small plastic container on the side of it for 2ea. small automotive style fuses.
Does anyone know where they go?
May of 1969 is date of issue, a 4A084 mod SF 10-0,
but it looks like any mep 10k I've dealt with for years.
This lack of charging affects the oil pressure guage (intermittant) , I don't know if the Hour meter is reading, I have a -14 manual but am looking for a start point.
I plan on using the 3 phase to run my lathe till i get my shop set up. sure will appreciate a clue on where to start. I'm sure what is behind the pully wheel (for pull rope) at the front of the generator is ok, i blew it out, it was pretty clean, I'm real unsure what to measure for output from there and i suppose it goes to the rectifier from there, then batteries, guages etc.
jimmr
yes, item 7. There are two under that transparent cover plate (#6) it'll take me a couple days to get photos on here. I'll see what sort of a TM I can find but when I was looking at them a 4A084 wasn't seen, not on a first pass.
jimmr
took 5 photos with my cell phone, sent them to my e mail address and only one shows up. i measured 26-36 vac from the pully at the front of the engine and measured it going into the rectifier, nothing is coming out of the rectifier no matter which way i measure it. I'll paste in a temporary or else just buy the thing from eastern surplus i guess ................. i saw they had one on there for sale a week or two ago?
jimmr
I should of gotten the other TM when i ordered a new voltage regulator ($38 but $48 to ship it !!!! ...... anyway, i've a idea that since it was run with no oil filter inside it the pressure switch may of activated so i'm tracing that back to the appropriate relay.......... this would no doubt be a easy issue for someone that actually knows electricity, (i just play with it) but i think i'll solve it......... maybe?
Ray70
6,691
West greenwich/RI
$48!? Does that particular TM weigh 40 lbs. or something? it should qualify for USPS media mail for like $5, sounds like someone is trying to rip you off.....
