Rusty sash guides. Very abrasive and do not slide nice in the side glass track guides
I polished the guides on both sides.
This is the other side of the sash. It was also polished with a 2" Rolok polishing pad.
This is a long discontinued part that goes in the bottom of the gate. It is activated when the window is in the down position. This part is shown in the catalogs of LMC and others but is not available. I bought 2 Genuine GM ones from a parts house that showed them in stock. I paid $100. each for them. I have them for Red Riding Hood project and one just for having. Not needed.
Brand New A C Delco regulator right out of the blister package. I installed it and reassembled the entire gate. I cranked it up and down a few times and it popped at the top. I opened up the gate again and removed the regulator. It is scrap. Missing teeth or they just ground off in 3-4 up and down cycles. ??? I will post what I found next post.
Not sure what went wrong. I threw it on the scrap pile. I had it for at least 10 years. I had more still packaged and just unpacked a second one. I thought about tearing it apart and pictured the spring pressure injuring me so I refrained from that. Scrapped it.
I cleaned and grease the lower sash guides.
I drilled an 1/8" hole into the outer skin and caught the inner reinforcement with a self tapping screw. if I were doing a restoration I would have been more through.
It pulled the pieces together and I could see a difference in the gate after I greased and adjusted the strikers and wedges.
I used the correct screws to attach the end covers on the gate.
The owner supplied a spare tire carrier from a civilian K5. I thought it was torch time but decided to give the Snap-On 1/2" cordless a shot first.
Nailed it the first shot. I pinched the nut in the vise. I thought about calling this M1009 the skull splitter. Nice laceration on my head.
Like I mentioned this is not my restoration work. I am eyeball deep into just getting the project fixed. We all know how one thing leads to another. the top was missing 6 side rail bolts. Why? How? Thank you for looking. Have a Great Day and Be Safe.
Bent bumper fixed. It was rolled in pretty bad. ratchet strap hammer and tree.
I think that was rolled in pretty good.
Rear gate all rebuilt and license plate moved to left side and LED light installed along with a B/U alarm at customers request.
Center console installed.
I installed a siren and PA system at customers request. Happy Happy. This project is completed.
I am ready to say good bye and move onto Mr Rusty. I have a lot of work to do on that truck. I need to get working on my own stuff also. I think the underside of the hood needs sanded and painted on my decade rebuild. I can do that also. Hand sanding is fine. Do it right or not at all. Have a Great Day Be Safe.
Long Day today and HOT. I juggled several tasks and accomplished more than I expected. I fell short of getting the grass mowed but tomorrow s another day. I did a lot of work on lawn equipment and after all was ready to go back together I discovered I had the wrong cable. Minor set back. It was an opportunity to wash and clean every part I removed which I other wise would have just reassembled. NOT. But I done an extra special cleaning and serviced my air compressor. I did manage to get home just in time to prime the left fender and door edge on my decade project. Lets see if I can get to the finish without doing anymore damage. I also did remove the hood and set it up on steel horses so I can sand and clean the underside. No spraying chassis black or undercoating. that would be too easy and sloppy and quick. I want attention to detail. I have it all set up and decided it was time to rest for the day. Have a Happy 4th of July. Enjoy your day and Be Safe.
Water base Flat Black paint. Heaven sent. No harsh chemicals and I used it before it sprays nice and cleans up with soap and water. Don't let it dry on your skin. It will require a brillo pad to get it off.
5 wheels for my M1009 Decade Wrecked rebuild are painted on the back side only. I know they are painted right this time. The paint looks good and is drying nice in the sun. I did learn a lesson. do NOT place a hood outside upside down and let it there a couple days so you can sand it. If you don't get it done and it rains it holds about 5 gallons of water and makes sanding it next to impossible. it is back in the barn leaning against the wall. I will give that another attempt very soon. That must get done. I am completed with my CUCV work for the day and have other tasks to complete. I am in dry clothing again and will give it another attempt. More later. Take Care.
It has been a while. I have been busy with a dozen or more projects. I had a few hours and have been dragging my feet on te underside of this hood. This hood is perfect or I would not bother sanding and painting the underside. I could have undercoated it but that is the lazy way. I wanted the original OD green on the underside. I sanded it a few hours with the DA and hand sanded it a few more hours. It came off a township truck I bought back many years ago. It was 1986 K30 cab chassis. It was nice but the frame rotted in half. Salt spreaders tend to do that. I will work on it Monday after I come home. It had a quickie paint job. It looked bad yellow. But it is bad now getting the red off. I think it is about ready for sealer. I will check it out Monday. Take Care. Enjoy your Weekend. I think I have everything on the underside of that hood feathered in and tight.
I kept true to my word and finished sanding the underside of the hood.
I flipped the hood over and closely examined the outer surface. Still perfect shape. For now I will set it aside and move onto getting the tailgate jam sanded/scuffed and painted.
That should be fairly easy because the inside is Line Xed 95%. The outer surface of the gate needs no work also. I need to keep working at this. I did manage to get my Yanmar Diesel air compressor running.
I also started to get the left inner fender installed. I was already to put it in and to my surprise there were no J-nuts in the fender to install the apron. I fixed that quick and called it a night. Tomorrow I want to flip the hood over again and sand the red off so I am not sanding all that red into my clean engine compartment.
Have a Great Week. I will post more progress as it happens. Be Safe.
The tailgate crank on the M1009 project is still not operational. I only remember that when I was sanding the gate last night. I did have some small dents from the trailer hitch in the lower gate.
I still have to gut out the entire gate. I need to buy a clear rear glass and get the crank out and do some diagnostic and repair on it. I have a few parts cranks. I need to get a codded lock cylinder.
But the gate will need to be edge and jam painted then hung on the truck. I will do the disassembly after the gate is hung and adjusted. Storing and moving the parts does more damage when they are unattached. More later. The Mercedes project is in full swing and I am making some progress. That is a nice looking car but in a way it is a pig with lipstick on it. Someone converted a sows ear into a silk purse and hung it on an unknowing buyer. Have a Great Day.
I went on a hunt and found my stash box of M1009 gate hardware. I found a few drivers that have no keys. I will be taking one driver to the locksmith with a CUCV key to get the cylinder coded.
I actually had time to get my parts set out cleaned, taped and sealed. Hitch, gate inside and underside of hood are all ready for paint.
Next will be the paint and the installation. That is a forward move. A little at a time. No rush. Everything done as carefully as I can. Thais Rig Red's hitch hanging there. It was primed and sealed. I will just paint it green when painting the gate and hood insides. Have a Great Day. Be Safe. Take your time and do it right.
Well do I get any points for an honest attempt? After work I opened up the barn doors and began getting some parts together for a customer that was stopping by. Mainly a right door and a fender. About 10 minutes in my Grand Children showed up. I finished gathering the parts and it was starting to rain. Keeping kids in the barn with painted parts hanging from the ceiling and on stands never ends well. I opted to close the doors wash up and go inside the house for instant entertainment. Now supper is all done and I don't feel like going back out. It is still raining a bit and I do deserve a few hours rest on occasion. I really try and stay focused as much as I can. I the first picture with the unsealed hood you can see the Mercedes less the left front wheel and rotor. Still waiting for parts. Rain prevented me from doing any real work. Which is fine. I am inside with my Family. More later. Take Care and Be Safe.
