1986 M1028, 454 Gasser......?
rickf
2,246
Pemberton, N.J.
A tunnel ram would be 2-4's.
Is this a mud truck, or something else?
A Tunnel ram can be one four, two fours, three twos. Any combination on a tunnel ram manifold. This is actually not a tunnel ram per say, It is a single plane high rise but it is the same basic idea. The Dart engineer is being VERY optimistic! A lot depends on the cam. You are going to need a bare minimum of 290 at .50 just to move enough air in that thing and I am betting you are closer to 312. It may start to pull at 3000 but it will not produce any real power until 4000 and up.
Edelbrock #7161 would be a good choice. That would give you bottom end starting at 1500 depending on the cam and what carb you are using. For street/mud you don't want to go above 750 cfm.
Rick
rickf
2,246
Pemberton, N.J.
My bad, Is it the 366 or 427? I used to get the spacers for 427 TD from Offy. I don't know if they are still in business but I might have my old Machinist books that give part numbers for the spacers. I will look around but I am n the middle of a renovation so stuff is boxed and scattered.
Rick
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
Rick
You are correct. I have seen diferent top adapters for many combinations, but REAL tunnel rams run 2-4's. :twisted:
ODdave
41
lansing michigan
Yea, there are adapters still around, More than one place makes them.
As far as that intake, You will be dissapointed, and the carb. well thats really gonna be a bad thing with that intake. You would be much better off with a closed plenum dual plane intake. The one you have will greatly reduce air speed on that setup causing poor fuel atomization. Like 6.2 power with BBC fuel economy.
islandguydon
787
Michigan
Bob,
Nope, Before I bought it I wanted a general consensus of the pros and cons. The weight of the Conn's was overwhelming and I can build my own if I want a flatbed that bad. I believe it went for $4,350.00 I was beat out in the last 5 seconds. Say sara, sara.
I look at it this way it was a nice truck with gremlins. There is always another one around the corner. Happy Holidays Bob.
