1990 998 Headlight Issues
darylwiz
Orange County California
1990 Humvee
Here is all my issues
3 Switch Turned all the way to the right-
No Headlights
Turn blinker to the right side (passenger) , turns both front blinkers on, Turns rear right blinker on Running Lights work
Turn blinker to the left side (Driver) nothing up front flashes. Nothing in Rear Flashes. Running Lights work
One Right Click over
Turn Blinker to the right (Passenger) front left signal flashes right rear flashes
Turn blinker to the left Right Front flashes, both rear flash. Running lights
High Beam Indicator on Dash lights up and turns off when pressed off and on
Problem is I can’t get the headlights to work….At all…..
Any help would greatly be appreciated or any electrical geniuses in California, Los Angels or Orange County.
INFChief
1,344
New York
1990 Humvee
No Headlights
I don’t have a TM or a schematic - but I vaguely remember that the turn signal switch has something to do with headlights. I’m either thinking of a much older vehicle or I’m hallucinating….
mgFray
940
Southern Minnesota
My limited trouble shooting on my 1988. Work in this order:
Bulbs, grounds, switches, connectors, wiring.
On my own vehicle, multiple bulbs were out (and had been replaced with 12V versions). A few of the grounds were lose. Switches were fine. And one of the connectors was broken internally. (And I've seen signs of someone screwing with the wiring, but so far I've not had to diagnose that.)
Hummer Guy
773
United States Louisiana
1990 Humvee
No Headlights
Sounds like a grounding problem
